Brake problems!
Cnp22
Just a V6......
Cleburne tx.
When I'm turning to the right and hit the brakes there's a slight grinding noise coming from the front passenger tire, and i can feel the grind in the pedle, the pads are fine plenty left. And also just when I hit the brakes or sometimes when I take off there is a clunk from the same tire. Bad caliper? Abs sensor? I have no clue iv had the tire off can't find anything loose or bent looking.
typical symptom of bad wheel bearing.
grab the top of the wheel and pull/push and you will likely find that it moves much more than it should.
Cnp22
Just a V6......
Cleburne tx.
Damn didn't even think of that! It's been clunking since we got it. I'll go and check it when I get back home thanks guys.
itwonder
VA
Did you check both the inner and outer pads?
Cnp22
Just a V6......
Cleburne tx.
I tightened the wheel bearing nut and it fixed it for now. When I change the wheel bearing is there anything else I need to do while I got it apart? Is there a certin brand I need to get or will the cheapo work? Thanks.
itwonder
VA
Autozone ValueCraft works. Problems have been reported with Timken.
