Tigerdadgc
Last week my left rear caliper froze up while I was at the Nascar race in Richmond, and the pad wore down to the rivits which in turn tore up my rotor. I think my caliper froze up when my girlfriend jammed on the brakes at an exit ramp. I tried every thing to turn the piston in on the caliper with no luck so I removed and replaced the rotor, caliper and pads on the left rear. I turned the ignition on and got zero flow to the caliper. I then started the motor and the bleed appeared to be normal. I have been driving the car all week with no problems, pedal felt great. Today I rolled up to a stop sign and the pedal went all the way to the floor. The brake fluid is full and I have no leaks anywhere. Does anyone have any idea whats happened. Do I need to bleed all the brakes? I need some help!!!!!!
Mike
Mike
