Brake pad recommendations.
jmpSHO2nd
Massachusetts
i liked the PFCM pads A LOT
I also like the OEM Ford pads I have now on a different car. I'd really have to put them side by side to see which has better performance when the speeds get high. But they are both awesome.
I have installed some Wagner Thermoquiet pads in the 598 size on a few customer cars and they also stopped great with decent intial bite for a ceramic pad! These are just with me test driving it after the job for a few minutes though, I haven't had to live with them for years so I'm no expert on how the pads shape up in the long run. We use them on customer cars almost exclusively without complaints
I have a set of Hawk HPS I'm going to try next
Same thing here with the thermoquiet I installed a few for customers but never on my own vehicle. Not sure if they would hold up to my aggressive driving.
I contentedly used the inexpensive PFCM pads for many years, but never liked the cold/initial/emergency bite performance on the street and carbon deposits on the rotors on the track. After running a set of Carbotech XP10 pads on the 96 upgrade caliper/rotor combination at the track, I retired the PFCMs for the Carbotech 1521 street compound. All I can say is I am very impressed with their coefficient of friction, cold bite and resistance to fade. I cannot imagine these pads fading even on track days with their temperature resistance up to 900F, but they are not recommended for track use by Carbotech.
I truly enjoy their powerful grip during frisky street driving and have depended upon their emergency bite in many situations of stop and stop quicker rush hour traffic. I will always use the XP10 compound on the track since I have it and a matching set of XP10-bedded rotors, but the 1521 compound is my strong recommendation for street performance and safety. See their compound descriptions below. They are a little pricier than lesser pads, but they are not lesser pads. You will be amazed.
http://www.ctbrakes.com/brake-compounds.asp
hawkeye18
Sorta cares
Norfolk, VA
>has won multiple SCCA Solo 2 and Prosolo National Championships
>Bobcat 1521™ is NOT recommended for any track use
:huh:
:huh:
Not quite sure what you mean by the comment above. SCCA Solo 2 and Prosolo are autocross, not "track" events. The brake loads and temperatures for slowing a car repeatedly from 80-120+ mph are much greater than those for an autocross event.
jmpSHO2nd
Massachusetts
So I ended up going with the Ford OEM pads (PN: XF3Z-2001-CB) and I think they stop better than the Hawk pads did. I am very pleased with them. Of course I got into an arguement with an auto parts store about the motorcraft and Ford pads not being the same.
RonPorter
SHO Club of America
Lake Orion, MI
Yeah I meant HPS, they are very noisey and they killed my rotors. After one year there a lot of grooves in my rotors which now are squeeling pretty pad. I had decent rotors too.
It sucks because there is alot of meat left on the pad but I can't deal with the noise.
There had to be other issues. HPS pads may be slightly more noisy than factory crap, but not much at all. AND, they are VERY rotor-friendly.
Pads that **** rotors, like a number of race pads, do NOT put grooves into them, they were them down smoothly as if they were grinding stones.
You had other issues with proper pad/rotor bedding, possibly not having a good rotor surface when you put the pads on, or sticky pins or caliper.
Unless you get the situation squared away, ANY pads will do the same.
Hawk HPS, EBC Green or Yellow, Carbotech Bobcat (or is it a new name now??), and Porterfield R4S are all good upgrades for agreesive street driving and autocross. Even the old standy, PFCM pads, do well.
Sounds like those rotors are trashed. Go to AZ *** get a new set of the cheapest rotors they have. Here is an oldie but a goodie on seasoning new rotors:
http://www.shotimes.com/brakes/part1.html
And when you get the new pads, follow the instructions for bedding them in. And make sure that pistons and poins move freely. Also FLUSH all the brake fluid, and make sure it flows freely. A swelling brake hose can keep the caliper from releasing.
jmpSHO2nd
Massachusetts
I do at least 10 brake jobs a week so I doubt it was anything I did. When I removed the pads and rotors all pins were sliding fine and I regreased them before reassembly. Rotors are replaced with Centric rotors. I don't think I would ever use an AZ rotor.
RonPorter
SHO Club of America
Lake Orion, MI
I contentedly used the inexpensive PFCM pads for many years, but never liked the cold/initial/emergency bite performance on the street and carbon deposits on the rotors on the track. After running a set of Carbotech XP12 pads on the 96 upgrade caliper/rotor combination at the track, I retired the PFCMs for the Carbotech 1521 street compound. All I can say is I am very impressed with their coefficient of friction, cold bite and resistance to fade. I cannot imagine these pads fading even on track days with their temperature resistance up to 900F, but they are not recommended for track use by Carbotech.
I truly enjoy their powerful grip during frisky street driving and have depended upon their emergency bite in many situations of stop and stop quicker rush hour traffic. I will always use the XP12 compound on the track since I have it and a matching set of XP12-bedded rotors, but the 1521 compound is my strong recommendation for street performance and safety. See their compound descriptions below. They are a little pricier than lesser pads, but they are not lesser pads. You will be amazed.
I'm on about my 3rd (or is it 4th??) set of AX6/Panther Plus pads on the LGT, and I LOVE them. They stand up to track days VERY well. I was swapping out to HPS for the winter, but I leave the AX6 in year-round. Yeah, a bit dusty & noisy, but the braking performance, even when cold, makes up for it.
I was a fan of the Porterfield R4S on a couple of the SHOs. The Invoice always said "Not For Track Use", but I did anyway. For a basically stock SHO, they worked well at the track. But, on both sets I had, after both had two track days, the front pads split down the groove in the center. The still were working, though.
RonPorter
SHO Club of America
Lake Orion, MI
There are MANY of us who have used the cheap AZ rotors with the '96+ SHO brakes over MANY track days over the last 10+ years, and they work just perfect.
Unless you are running a race series, or just gotta have the "look" of a certain rotor with holes, slots, or dimples, spending more than you have to is a waste of money. There is no additional performance to be gained with a pricey rotor. Same with spending big $$$ on brake fluid like Motul.
RonPorter
SHO Club of America
Lake Orion, MI
Well, I hafta say that, across the SHO lists and Forums, The Legacy GT forum, as well as the 911 lists I was on when I had one, yours is the FIRST story I've heard with those problems with the HPS pads over the last 10-12 years I've been familiar with these pads.
Again, grooves in a rotor are NOT from pads that are not rotor-friendly.
RonPorter
SHO Club of America
Lake Orion, MI
Scott, how much dust do the Carbotech pads produce compared to the PFCM's?
The Carbotech Bobcats have far less dust than the PFCM. Bobcats have been a favorite pad of the Gen 3 guys for years. The trade-off with the cheap price of the PFCM is that they dust almost as much as my Carbotech AX6 pads.
jmpSHO2nd
Massachusetts
I don't have drilled or slotted and I have warped inexpensive rotors before not sure where I bought them but it did happen. I payed a little more for the Centrics than what AZ charges for a rotor.
I too have found that the Carbotech 1521 "Bobcats" are low dust pads compared to the PFCMs. They are quite easy on the rotors and wear at a very low rate. After the incredible braking experience at lapping days at Texas World Speedway with the XP10s, I tried using them on the street. Their friction coefficient was almost laughably high and required a delicate touch on the brake pedal. However, the noise and dust were a bit much to deal with on a daily basis. it was then that I purchased the 1521 "Bobcat" pads. I have been a Carbotech fan for street and track ever since. For the moderate amount of extra cash, you guarantee a high performing braking system that is likely the most important safety feature on the car. The cost/benefit analysis of these pads reveals a huge safety and performance increase for a minor expense. Don't be cheap on brakes. Or tires.
Westerly, RI
Agreed. Properly bedded, seasoned, salted and peppered, I've had nothing but good luck with the cheapos. The set I have on the 92 now have seen two cars, three track days, and two sets of pads.
hawkeye18
Sorta cares
Norfolk, VA
I'm willing to stake a large-ish amount of money that up to 90% of warped rotors are caused either by deposited pad material, or improper seasoning procedures. Specifically, people bedding their pads before they season their rotors.
It'll happen every time. There is a reason you season your rotors first; place an ice cube in a glass of warm water and watch what happens. The ice cube immediately cracks and fractures internally. Why? There are internal stresses in an ice cube, and when you subject them to thermal shock, they will, instead of ironing themselves out, have basically the equivalent of an unchecked muscle spasm that rips the internal structure apart and causes... you got it, warping. But ice cubes are brittle, so they crack instead.
Rotors are no different. There are internal stresses in them from the manufacturing process, and they are uneven. If you gently heat the rotor up first (akin to letting the ice cube melt on the counter - no cracking!), these stresses will gently relieve themselves and you'll have a unified crystalline structure. If you heat it up too fast, the rotor will warp from the stresses.
ajd32186
Clinton Township Michigan
I always use a ceramic brake pad on any car I drive.
akebono makes great pads for high end cars and now they are sold at bell tire.
Also akebono has another line of brakes that are good but I cant remember the name.
RonPorter
SHO Club of America
Lake Orion, MI
Nah, I disagree. 99%+ are from what you mentioned.
I have had it in the past from cheap pads. Funny how those "warped" rotors can take a cleanup pass on the rotor grinder and still be good for another go-around.
But, lotsa companies making big $$$ selling expensive rotors, brake fluid, and full brake kits to street guys. Guess I missed out on my chances to make a fortune off the gullibility and misinformation of MANY car "enthusiasts"!! :evilgrin:
Nomospm
