jmpSHO2nd
I need a good set of pads for the front of my SHO, I have the 96 brake upgrade kit. I have Hawk FPS in there now and I will never use those again.
I have always used the OEM Ford pads that came on the '96+ SHO's.
It is p/n: XF3Z-2001-CB.
You must make sure it is the OEM Ford part, as the Motorcraft equivalent is not the same and is not that good.
I use these pads on my SHO, my SLO (with the SHO upgrade), on my Mark VIII, and on my parent's '01 SLO. They are great!
Doug
Do you mean HPS? What didn't you like about them. I have a set I'm going to try.
I have used Performance Friction carbon metallic pads on both my stock and PBR calipers. They have been gentle on the rotors and performed excellent.
Bob
What do you want them to do? Just street driving? Street and track?
The Ford OEM pads are actually quite good for what they are. Most modern compounds are pretty good (I think HPS is getting a bit long in the tooth, actually).
I go to the track once or twice a year so I am going to try Ford OEM pads and see how they work.
Bob
You can try Akebono Ceramic pads. They don't bite as hard as the HPS, but they dust about 5% as much, and they make no noise. They're quite easy on rotors as well, and bite well enough when you get past the initial bite.
Do the PFCM pads have a good bite to them? I was thinking about picking up a set for my explorer...regular duralast pads are...meh at best.
When I was working for NAPA they came out with a "hybrid" cermaic pad that all of the customers we sold them to really liked. They are ADO or Adaptive One brake pads. They are the most expensive choice, but you get what you pay for (in most cases). No noise, minimal brake dust, and a Long life.
