NCSHOracer
Fear The Rasp!
I replaced the drivers rear caliper on my SHO about 10 minutes ago, and the piston won't stay out. I can pump the brake w/ or w/o the parking brake on and it doesn't make a difference. The pedal is as hard as a rock but when you go to look at the caliper it hasn't even made contact with the pads. If you pump the brake and get out you can see the piston slowly go back inside the caliper. Any idea what might cause this?? I tried bleeding the brakes but it just keeps going back inside the caliper.
