HyperMikeD!
FordBastard07
I was pondering out in my garage the other night and heres my dillema with my Shagon Wagon...
Stock '92 GL Wagon booster has no ABS and 4 ports coming out of the master cylinder. 2 for the front and 2 for the rear.
'93 SHO sedan booster has 2 ports coming out of the master cylinder that goto the ABS computer.
The SHO master cylinder has a lager piston than the GL so I want to use it but cant use the stock wagon brake lines that go to the front and rear.
Unless...I install a bias valve close to the SHO booster and run new line to the rear. No biggie. I have everything to do that.
With the 13" rotors and Cobra calipers all around dont you think that the bias valve would be a good idea ?
Lemmeeknow whatcha think...
MikeD.
OBTW...I can get brand new power booster and master cylinder for about $125.
MikeD.
