Alright. So I finally got some money together, a good chunk of it, and I'm ready to turbocharge my SHO motor. Don't try talking me out of it, the motor is already out of the car
I stripped it down to the bare block, and I'm ready for some internals.
The real question I would like to know, is what you guys went on, TIM (toolman) especially, for compression ratios and what/where you got your pistons/rods from. Did any of you use different bearings as well?
Also, After the internals, come the head. I don't know what luck you have all had with this, but I would like to run stage 2 cams, figuring the longer duration should help cram even more boost into the engine. An intercooler is a great idea of course, but I was also thinking of a stage 2 water injection set. They are pretty in expensive, and from what I've learned, work wonders.
Intake wise, I wanted to hone it out, I saw shoshop did some good work with that. Just wondering why one is so much cheaper than the other?
Larger valves I think would be good for the head too. Not sure if anyone ahd any luck with this, but would love input.
That's about all I can think of off hand for hte basics, until I get some more $$.
Tranny wise will be expensive (quafe and cyro'ed gears) but all in good time.
I wanted to run about 8.5 compression, I figure it should be enough with the waterinjection and intercooler to have no knock, and still have a good spool up time. I don't want to run too low, and have too much lag, but I don't want it too high either and get pre-detonation.
Turbowise, I was thining a 60-1 like Tim is running, or possibly a 62-1. I still wnat to do a bit more research about that, but it seems like a good turbo, good size, but I don't know if TIM gets alot of lag with it.
Thanks for any comments, I really want to get this project going now that I've got everything.
Jake.
Jake.
That low?? I'm thinking 9.0 should work just fine, I've got a saab 9000 turbo, all stock with a T3, and its got 9.1:1 and the turbo spools up nicely.
