Blown '92 almost ready
SHO Dude
Sponsoring Vendor
Sponsoring Vendor
Southeast
If you're running the streets of Maryland in the near future and run up on a green '92 that sounds like it's got a bad alternator bearing, you might want to think twice about taking it on.
Photo 031707 012
Photo 031707 004
Photo 032507 010
Photo 031707 009
This one is our latest blower car. It's got a bunch of our stuff underneath, under the hood and out back.
Should make *the* noise quite nicely.
Vortech Shaft Drive V2-SC
Custom ASP Pulleys
48lb Accell Injectors
BA2400 MAF
SCT Tuning
FPS Built tranny with Dual Diaphragm clutch
& Quaiffe differential
FPS/PP True Hi-Flo Y-pipe with cats
Walker/Dynomax exhaust system
FPS 12" Brake Kit
FPS Aluminum Subframe Bushings
FPS Subframe Connectors
FPS Aluminum Control Arms
Jarrod
OK SHO - now in TX!
Midland, TX
Looks fantastic, Doug!
I really like the look of those shaft driven kits. Have you ever experimented with any time of after/intercooler..?
ty91sho
EVRYDAYHUSTLIN'
st.cloud MN
can you get the oil cap off to change the oil? ahah i just seen that and was like that looks alittle tight.:nut: anyway i like it! lookin good!:thumb:
SHO Dude
Sponsoring Vendor
Sponsoring Vendor
Southeast
We've been looking into the FMIC and have figured out a way to do it. Just haven't had the time or the need as yet.
At 9psi of boost, these cars are consistently putting down 325 on the tires and yielding 25-26mpg on the highway.
A FMIC would allow for more fuel and more timing, so maybe on my car. We'll see.
SHO Dude
Sponsoring Vendor
Sponsoring Vendor
Southeast
Comes right out. Slips under the shaft. You need a funnel to fill it, but the cap does come out.
Mels
SHOVELHEAD
Brookfield CT
Looks good. Looking forward to more pics as you progress.
There was a time when I too considered Supercharging my car. At this point however, I enjoy just driving the thing :)
SHO Dude
Sponsoring Vendor
Sponsoring Vendor
Southeast
gtstang1967 said:
thats a nice 67/68 mustang coupe next to the sho .makes me miss my 67. nice setup
Thats' a Pro Street drag car wiht a 600hp Cleveland and a C-6. Runs 10's.
The next one is a '69 fastback with a 400hp '03 Cobra motor, 6sp tranny and independent rear suspension. The '70 Cougar with the 6.8L V-10 Ford truck engine and 5 speed is getting done first.
K-Dawg
Treasure Coast, FL
How about a air/liquid cooler? It looks like there would be room for a single core unit on the driverside of the engine bay there. That would keep the charge piping short.
Phoenix
SHOHOLIC
QC , Canada
If you look at the first pic , lets say you wanna add oil into it.......
Heheh just messing around , looks good :thumb:
Off Road SHO
Moderator
X2
Tom
1slickRED89
Guest
Toledo Ohio
that V-10 car is awsome, plus if the owner wants more kick he can have the 6.8L 3 valve engine installed for an instant 60hp and 30lbft upgrade.
TT SHO PROJECT
OHIO
yeah... or for less money get injectors and a kenny bell roots for it and have an instant 300rwhp jump (hmmm 600+hp v10) :evilgrin:
SHO Dude
Sponsoring Vendor
Sponsoring Vendor
Southeast
It will be. V-10, 5-speed, 8.8" rear end with 3.73 gears, 13" Cobra brakes, 4 wheel disks and hydroboost.
The 9,000lb Econoline that the engine came out of, got about 9mpg. In my 3,000lb Mustang chassis, it'll get close to 20mpg. The engine makes 315hp and 345ft-lbs of torque. It makes over 300ft-lbs from 1600rpm all the way to about 4200rpm. So when you're out and driving about, if you're over 1600rpm, you've got 300ft-lbs or more to work with. This means that in most cases, you won't even have to downshift. Just roll into the pedal and off you go. But in those cases where you do need to grab a gear or two, simply push in the clutch and pick the one you want. The transmissions is straight out of a Mustang Cobra.
The next one is gonna be a '69 Mustang Fastback that's getting a '04 Cobra engine, 6-speed transmission and independent rear suspension.
Should be a gas.
SHO Dude
Sponsoring Vendor
Sponsoring Vendor
Southeast
Starting to take shape...
Photo 040707 006
Oiling system, discharge plumbing and bypass, then a little tuning and off we go.
SHO Dude
Sponsoring Vendor
Sponsoring Vendor
Southeast
Gotta love the Load with Failed MAF table in the stock programming.
Th FirstStartwithBoost
Few more things to wrap up. Inlet and discharge plumbing, coil bracket, MAF and tuning. Then it'll be ready to make the noise.
