blinking air bag light..
FlaSho
florida
Before I bought my 97 SHO, it took a light hit to the nose which caused me to replace the entire header panel, fender and hood. I DID reconnect the air bag sensors on the front, but I get a constant blinking Air bag light still.
any ideas?
Thanks.
jmpSHO
Massachusetts
any ideas?
Thanks.
When the airbag light blinks it is trying to give you a code. I know the Gen 2 uses a two digit number, not sure about the Gen 3. Count the number of times it blinks and post the code.
SuperHO
Mental Patient
St. Joe, MI
i can't speak for the gen III since i've not had that problem, but my 95 started blinking at me once, so i pulled the bulb out of the dash. well, then the airbag computer started beeping at me. so i unplugged it, and now, no more problems!
medgraphsho
Bill T.
Bridgeport, CT
Dont quote me, but I believe you may have to replace the air bag module also. If the car is in an accident, the module detects this and has to be replaced as well. did the airbags go off?
mattsho1993
SHO owner
albion, new york
How do i re-mount it, i took it off when i change the radiator and took out the one for the a/c. I put it back on properly does it have to be grounded better or something.
FlaSho
florida
Ok, it blinks four times and then keeps repeating....
Whats that mean?
There is a code 44.
— No AIR BAG indicator - Inoperative indicator circuit
13/53 Air bag circuit short to ground driver/passenger
14/54 Primary crash sensor circuit shorted to ground
21 Air bag diagnostic monitor ground circuit open or not mounted to vehicle properly
22 Safing sensor output circuit shorted to battery voltage
23 Memory clear circuit improperly grounded
24 System disarm failure or internal diagnostic monitor fault
32 Driver side air bag high resistance or open
33 Passenger side air bag circuit high resistance or open
34 Driver side air bag circuit low resistance or shorted
35 Passenger side air bag circuit low resistance or shorted
41 RH primary crash sensor feed/return circuit open
42 LH primary crash sensor feed/return circuit open
44 RH primary crash sensor not mounted to vehicle properly or ground circuit open
45 LH primary crash sensor not mounted to vehicle properly or ground circuit open
