Blinkers
rkmvca_sho_95atx
Mountain View, CA
Jeremy --
Good advice. boink
I replaced the left brake/turn lamp and all is well. I don't know why it was behaving so funkily earlier ... I can only assume the right one will go out shortly, too. But at least I already have a replacement bulb for that one now (had to buy a 2-pack)!
thanks
Rich in Northern Ca.
ian559
Cincinnati. oh
First I had no flashers or turn signals. I replaced the relay. On my 95 atx it was above the fuse box and a real pain to get too. After fixing that I had to change out the multi function switch on the columm to get everything to work right. It took me like 5 days to track all of it down. Sometime the simple things can be the worst and most maddening
Lara_Tharp
Amarillo, TX
I got my blinkers fixed. Thanks to everyone for helping. If anyone ever needs to replace the flasher relay, pry out the dimmer/auto lamp panel. It's right behind that and it makes it a lot easier to get to than going up under the dash
