blend door stuck... cold air
ohfosho
ontario SHOwner
ontario, canada
hey guys, i looked on SHOtimes and it says it usually 'fails' in the hot position. it has been 'fighting' with itself for a while now, but usually is ok. i canhear it moving often when the car is moving, and seems to stop when the car is at a stop light. then starts moving again when the car does. i think it is just stuck, there is only a little noise when i turn off the climate control, it's the vacuum sound. but no usually blend door sounds no matter what i do. ran self test on eatc and got 02, blend door code.
is there a way through the firewall/engine bay side to get at it just to try to **** the track maybe? not to actually replace it, i am not pulling the dash, or even moving it...
HELP! lol
ohfosho
ontario SHOwner
ontario, canada
well see it was stuck on cold. i went full cold and then full hot, the blend door didnt make any noise... well good thing, it got unstuck tonight, im glad to feel some warmth... i jut wont touch the temp from 22 degrees (c) right in the middle... hopefully if i dont send it near the end of the line, and i keeps doing ok!
Brad kirk
