N3FOL
I got my speedbleeders last week and I was able to bleed my brakes earlier today. The bleeders were great and I did not realize how easy it is to bleed brakes with them. I had owned my 95 since 95 and this is the first time the brakes had been bled.
But, I had replaced the brake fluid twice by sucking off the fluid from the reservoir...Anyhow, I went ahead and bled the brakes doing the right rear 1st, left rear 2nd, right front 3rd and left front 4th. I did test drive the car after the procedure and the pedal felt nice and solid. Tonight...I wish I had double checked past threads on bleeding brakes and they state...right rear 1st then --->left front--->left rear--->right front.
Is everything OK even though I did not follow the recommended bleeding sequence?
But, I had replaced the brake fluid twice by sucking off the fluid from the reservoir...Anyhow, I went ahead and bled the brakes doing the right rear 1st, left rear 2nd, right front 3rd and left front 4th. I did test drive the car after the procedure and the pedal felt nice and solid. Tonight...I wish I had double checked past threads on bleeding brakes and they state...right rear 1st then --->left front--->left rear--->right front. Is everything OK even though I did not follow the recommended bleeding sequence?
