they go on the proportioning valve located in the rear control arm area. unhook the actuator arm, remove the plugs, install bias plugs. though, the bias plugs are not recommended for Gen1 stock front brake setups. 95 upgrade is the minimal upgrade recommended for the front if you are using the bias plugs.
