Tried fixing the a/c compressor today finally removed the clutch only to find out someone already removed the shim, so I guess that means I need a new clutch? Anyways bought a new belt since the old one was cracked and appears to be original (no markings whatsoever). We broke the tensioner trying all night to get the belt on, after a quick search I read it may be wrong length. I checked against the old one and they were almost exactly the same length the cracked one I figured had stretched a little bit. It's less than 1/2" shorter (I would say closer to 1/4"). If this is the case where should I get one? I bought a dayco belt #5060895 or 6PK2275 which should be 89.5". Should I try another brand or longer belt? We had a extremely hard time getting this one to go on.
