I just picked up a 1990 SHO that has been sitting for a while, and the blower motor would not come on. I pulled the blower motor out and retrieved a dead rat and the remains of his 5 star hotel he had built. Anyway, I checked the motor by straight wiring it, and it runs fine. I went to the junkyard today and pulled every BCM I could get my hands on, which ended up being 3. Two are out of 1989 cars, and one out of a 1991.
After trying all 3, the fan will still not come on. The manuals I have dont have an accurate wiring diagram of this set-up, so Im hoping someone on here might be able to help.
First I want to make sure I have this right. From the way the BCM acts, it seems that it only sends low to midrange (0-9) voltage to the fan, but when I manually put the fan setting on high, the BCM contact switches (clicks) and then the voltage source wire becomes a ground source, and the main wire coming from the dash unit would send 12v to the motor.
Im guessing this, due to when the BCM contact clicks, the wire that was sending 8 volts, drops to zero. It then shows continuity to the chassis ground.
When the BCM is sending say 8 volts to the motor, the motor doesnt have a ground source. The wire that should offer a ground shows no continuity to the chassis.
I guess Im wondering if I need to replace climate control unit in the dash due to its not providing a ground for the blower motor. Any info would be greatly appreciated.
