89shoZuL
Hey guys.. well i keep having these little problems after my 3.2 swap here's
the newest adventure...
Coming home on the freeway.. driving, stero on, climate control OFF, lights
on... all of a sudden.. ABS light turns on.. air bag light flashes.. lights in car
get brighter. The next thing that went was the lights.. they kept flickering
and getting dimmer and dimmer.. finally off.. all i had was parking lights. I
then pulled over. Just before turning off my car.. my tach started going
crazy, and i turned the car off right away.
Getting out and looking under the hood.. the vents for the battery had
popped off and smoke was coming out... there was no water or acid in the
battery, it had all come out.
I had the car towed home.. (took 3 hours to get a tow truck.. to add to it
all.. ugh
) soon as i got home i took out the old baking soda and made
sure all the acid was off the car and then took the battery out. I replaced it
with another one i had laying around in my 89. I hooked it up.. and the car
starts fine.
But i have some huge electrical problems... my unlock switch turns on the
lights in my dash.. my alarm doesn't work anymore.. keypad or remote.. my
lock switch works only when the car is on.. and acutally turns the lights on.
The radio does not work what so ever. The climate control works.. a/c and
heat. No interior lights work. I checked the fuses under the dash and inside
the hood. I looked at the two fusible links that i saw that run from the fuse
box under the hood, and there is powering going to them, 12.8V.
I'm completely clueless?!? and have run out of options.. i did a search and
found a post with someone with the same problem.. but only two posts were
made but nothing of help.
Help Guys!
Thanks~
EDIT: Forgot to add.. i JUST installed a new alternator.. and battery.. both
were working perfectly. I suppose the alternator could be bad and
overcharging the battery.. but that doesn't relate to these electrical issues..
right?.. sigh :cry:
all.. ugh
) soon as i got home i took out the old baking soda and made sure all the acid was off the car and then took the battery out. I replaced it
starts fine.
Help Guys!
Thanks~
right?.. sigh :cry:
