two days ago the wife and I went to go do some shopping and the battery was dead so I jumped the car off and noticed the battery light was on . So I stopped and had the battery tested it came back with a bad cell so i bought a new one . The battery light is still on unless i keep the rpms up then it goes out. So I did the old school alternator test and removed the battery cable since if the alternator is good the car should stay running and if it shuts off the alternator is no good. Well the car shut off , which tells me it is bad, so I took it off and had the alternator tested and was told it tested out fine by hitting 15 on there alternator testing machine at advance auto parts. SO he tells me to check the voltage regulator which should be behind th ebattery on the fender wall. Guess what nothing is there and I can't seem to find anything that looks like this pic to http://www.partsamerica.com/product_images//img/nie/vr450.jpg
So can anyone tell me where the voltage regulator is on a 94 sho 3.2 atx maybe even with a pic ?
thanks in advance
thanks in advance
