Battery light on
stevoboyd
north dakota
my battery light came on, but when i un hook the battery car stays running, meaning alternator is still working. my question is what makes a battery light come on besdies the alternator not charging?
-DVP-
NaNaaNaNAAAA!!!
0 .· ` ' / ·. Full Retard
Remove alternator, have it tested, buy new alternator, install.
It can keep the car running, but that doesn't tell you how well it is or isn't charging...
whiteguy3
Scott MacIntire
Silver Spring, MD
Replace the alternator for sure. You can get one from a local junkyard if you would like or from someone here on the forum considering they are fairly expensive new. Have the battery checked while your at it. Most auto parts stores will test and check both the alternator and battery for free.
sperold
Last to Know
Overcharging turns the light on as well. There are posts on this forum explaining how it all works (I think from Hawkeye).
I think it is too risky to nurse it back home, not only for your battery, but all your electrical components.
