battery light at high rpm
fenwayfan1
mansfield, CT
does anyone know why my battery light comes on and kinda blinks when i hit the gas, the lights dim and all too, its fine on normal driving but when i hit the gas and the rpms go up this happens, can anyone help? please!!
redSHO96
SHO Owner
Wappingers Falls/Utica NY
its funny, I read elsewhere that the whole battery light illuminating under heavy acceleration is normal, which I thought was really stupid and wrong but I believed it... I dont seem to ever get a correct answer from anyone I talk to besides here.
Mr Anonymous
Tire Wall
Sorry, I read "step on the gas" as anytime the accelerator is pressed, not just at high rpms. :bonk:
The high rpm issue is due to the voltage regulator clipping at high rpms. Other than the OE original regulators (which are not available separately), all other regulators are hit-and-miss with regard to their ability to regulate power output at high rpms, so the clipping is the internal safety mechanism to prevent an overcharging condition.
Falls SHO 1
Orlando, FL
My car has done the same thing at high rpm's since I bought it. Over 1.5 now...car still runs strong, I have had the alternator tested a couple of times just to verify its charging ability. I also wondered if it would produce the same results (battery light at high rpm's) if a "windstar" alternator was installed?? Thoughts??
Mr Anonymous
Tire Wall
That's what you have already.
ArkanSHO
Arkansas
I can attest to the alternator being the trouble but not necessarily failing. My first one would iluminate the battery light above 5,000 everytime and I would get the added bonus of an extre little punch at the same time. After about 6 months though I got nervous that it would just up an quit one day so I replaced it. I missed the little "kick" of power though so I traced the fields ground to the speedometer and wired a dual pole relay with a switch so I could manually shut of the alternator at any speed I wanted. Paul liked the idea so much he made an automatic version (VAK?) that worked at a WOT level drop in manifold pressure that would also activate an auxillary battery into the system to make up for the drop in voltage so the coils were getting a full 14 volts.
