Egg
Who?
Damn is it cold today, 6 Degrees with a windchill of -13. Went out to start my car today and it has no juice!. This has been happening to me for a while but my red top has always managed to start her up. Im thinking the cold is just a but to much for it this time though. Somthing that does happen when i go to get out of the car is the tone alarm will go off untill i jiggle the ignition. Somtimes i forget and this may be why it is dead. Ive got the battery on a charger as i write this. What i want to know is what is wrong with my ignition switch and if this is the problem before i go out into the parking lot and freeze my ballz off checking wires. Also what wires can i check real quick so im not out in the cold for hours grabing cold wireing. Thanks
PS: I forgot to mention that my battery is only taking 2 amps from the
charger which is 10 amps
Update: Well shes been on the charger for at least 45 minutes. It turned over twice then wouldnt turn over again. Its acting like the battery is dead but the charger says different. Another note is that i did replace the stock terminals on the cables and have checked them for tightness several times then tightened them anyways to make sure. I also used di-electric grease on the wires and terminals to prevent corrosion.
Dan
Dan
