munkee
Too busy...
Got my car running again! Thanks to shodude for the tranny and to everyone else for the info along the way. It looks like I will be doing the heater core next though. I think I bumped one of the outlets when I pulled the motor because it leaks pretty good now. (okay it leaks pretty bad) Anyway, I just connected the two heater hoses together for now, I will work on it later. I ran the codes and everything came up good except for the egr valve not opening correctly. Could that cause the car to idle a little rough? Almost got a ticket already too. I live right above the cop shop and I wasn't used to the new clutch, coming around the corner in front of city hall I started spinning because of the sand on the road. The cop came by all ****** off as I was going into the house and chewed me out. Oh well, at least he didn't give me a ticket. Ok, my final questions are, I have a squalling noise coming from the new belts area. Would that be from too loose or too tight of a belt, and is there supposed to be a bushing of some sort on the gear selector on a cable shifter? There is a lot of play in it and it just doesn't look right.
