ATX to MTX conversion
revhardSHO
Seattle, WA
I have the ability to pick up a cheap 95 ATX, running but with bad tranny. I have a few MTX parts cars here, what is involved in converting this to an MTX? Do I use the MTX subframe and ATX front mount? Thanks.
MerkXRTurbo
Vancouver, WA
I'm getting ready to do the exact same thing and have all the parts ready to go. Here's what I know so far:
-MTX subframe is required
-3.0 motormounts and accessories (including water pump) is also required, unless you build a custom front motor mount as shown here:
http://www.shoforum.com/showthread.php?t=113467
-If you're going to swap accessories, the front head needs to be modified to bolt the 3.0 alternator to it. An alternative to this would be to install a 3.0 head on that side. The rear head dimensions are the same 3.2 vs. 3.0.
-IIRC Coil pack is mount a bit differently between the two
-I plan to change out wiring harness and computer, but many do not.
revhardSHO
Seattle, WA
Sweet. So it looks like I just need to get a custom mount fabbed up (the guy just did the front 60k, so I'd rather go with the single belt 3.2 design. I do have an MTX computer if thats needed. Obviously all MTX exhaust components, and I'll need to cut a hole in the floor for the rod shifter. Seems possible since I have lots of MTX parts around. Thanks for the quick reply and info.
MerkXRTurbo
Vancouver, WA
Oh yeah, forgot to mention:
-3.0 exhaust manifolds and Y-pipe
-3.0 oil pan (not required, but the 3.2 pan requires extending the oil level sensor and then the bell housing would not be sealed off to the elements).
revhardSHO
Seattle, WA
Ok cool. I will use the 3.0 components, manifolds and oil pan. Doesnt seem so bad, really. Anyone selling modified front mounts for this conversion?
And I can use an ATX or MTX computer?
poffffd
