ATX shift kit install???
SHO SPD
SHO member #480
Naples, Florida
When I replace the ATX to a 95 ATX I would like to install a shift kit, but I dont have the slightest clue how, oreven where to buy one. Is the intsall easy? And wuld it be worth it?
ACNDT
South of Atlanta
No it is not easy unless you have torn into a ATX before and have the special tools.
The Trans-Go kit requires you to remove the valve body, the chain cover, and the front planetary assy. You have to take the valve body apart and drill some holes in difrent places, change out some valves. There are holes you have to drill in the planetary set for added ****.
I have done several and have the tools to do it so it goes pretty fast.
Randy
