Hank F.
I am no rookie at mechanical tasks. That said, I am more than a little intimidated by the whole FWD everything- in- one- bag- set-up.Are there pics to help a novice on FAQ's? I was trained on 55-57 Chevy's, of which there is NO task I couldn't do. But those vehicles had no electronic anything beyond a voltage regulator and a battery. I recently had a 97 Chrysler Sebring V6 that I trouble shot (shooted?) by plug and play until it no longer showed negative codes. This long-winded treatise is here because I have the pleasure of owning a 93 SHO Auto that has had good care for a car with 170k. The trans. was rebuilt by a local Ford dealer (Gresham) 6 years but only 37k miles ago. It now is leaking to such an extent that it is spraying on the exhaust pipe and smoking. It also judders and slips until I get it into lockup at hiway speed, after which it behaves as it should. The 3 part question is: A. is a complete rebuild likely to be needed? B. I have an available rebuilt trans. w/3k miles and a new tq. converter for $300(!)- should I just buy it and be done with it? C. If I do, can a marginally competent wrencher expect to be able to swap these out and expect it to work? Am I fooling myself thinking I have a prayer of accomplishing this job with NO previous FWD experience. I've done a couple of jobs that I got as a result of the previous owners' inability to put them back together correctly, and found them to be worse than blind-folded jigsaw puzzles. I want to drive this car-- Please help me go about it correctly.
