I have a AX4S that was rebuilt and working fine. Now at light throttle (not enough to drive on the street) it sounds and shifts great. At normal pedal pressure it makes a chattering/clicking sound just after it shifts into 2nd and then stops but will do it again anytime I give it more gas for a short time then stop. I have a 656 code but the TCC solenoid ohms out OK and I can hear it click if I power it up. What I need to know is if this solenoid is a on/off like the shift solenoids or does it get variable power from the PCM. I jumpered into the wires for it's pins 37/57 which are the 12V+ and the pin 53 which is the control from the PCM and I only get between 0 and a high of 2-3 Volts at any speed in any gear. Does anyone know what that voltage should be. I have checked the wires from the trans connector to the PCM are OK, so if voltage is OK that low I need help. I would assume the voltage would or should be more so maybe PCM bad? Thanks Larry
