So I hear a lot about people having under-steer issues with gen. 2 ATX's...
My ATX handles almost as, (or as good as) a RWD car.. I am frankly puzzled,
having owned SEVERAL of each... Maybe my bushings are so worn, they are
approximating a RWD norm.? My tire wear pattern is, moderate wear, outer front drivers. Moderate inner wear on both rear tires. Also, my car sits fairly low in the rear, this helps, I suppose.. I am going for snows/alignment soon, so I will post my actual specs. when I get them..
Let me say, I have ZERO understeer, I can rotate the car with the throttle,
or brakes, so, I can bring the ass around with NO problem at all..
I have been through the I-95 Pawtucket "S" curves at 100 mph, and around the
I-95 "Thurbers ave. curve over 100 mph.... ( No mean feat!!).. As, if you miss
either one, you wind up hitting a Jersey barrier, then going over an embankment.
Don't worry, I have lived near both for quite some time, and have edged the speed up 5 mph at a time, looking for 8-9 tenths.
So, what I am asking is, How does your ATX handle?
