I'm in the middle of doing both my head gaskets. For two years i've been driving around with it leaking. I went through probably three quarts in twenty thousand miles, maybe less. It also appeared that one or more of the corner oil drain holes was leaking. I was a little nervous after seeing a picture on here of a head that was damaged from a leak. I should be alright though.
I was just thinking about doing the gaskets and not bringing the heads to a machine shop, but i'm going to. When I took the engine apart I noticed two of three of the national cam seals I used were leaking one worse than the other. That was pretty discouraging, since they were replaced twenty thousand miles ago. Yes, I used anaerobic sealant.
Would anyone recommend using the cam seals that are going to come with my DNJ head gasket set? This time when I replace the seals i'm going to do it when I install the camshafts.
How do I set the timing belt tension if my aftermarket pulley only has one timing mark? Afaik I had to use more than one of the timing marks when I last set belt tension.
Is it recommended to reseal the oil seperator plate at this time?
I'm going to use copper gasket spray on the head gaskets. When I did head gaskets on my fathers subaru ej25 last winter it was highly recommended. I don't see how I can go wrong doing that here.
thank you
thank you
