are kyb gr2 exact fit replacement struts for a 93atx?
Mr95Gl
Mr Tire Iron
Brooklyn, N.Y.
The KYB GR2's are exact fit replacement struts. The fronts are PN: 235054 and the rears are PN: 334325. I'd recommend that you do the strut mounts to, as they'll have to be removed to replace the struts. Good luck!
NJatx
Branchville NJ
yes they are a exact fit. and again do the strut mounts and front bearings with the replacement because you'll need to take them out to do the job.
What springs are you putting on with them. From my experience the KYB's just arent strong enough for the SHO. But i guess its your only real option if your not willing to spend the money for Koni's.
sho-n-tell
north cackalacky
my sho is jtsho's old sho,i believe i read he has (or i have) cut moog coils.thanks for the info,i searched a little last night and found additional info on the forum too.thanks again
JTSHO
NO SHO
winston-salem,nc
Yes I put in Moog coils (cut). The struts are Tokico and I didnt replace the strut mounts so I would. I dont think the KYB's would hold up with cut coils. On another note you may want to check into getting a replacement tokico insert if you still can instead. I know they discontinued the whole strut but maybe the insert is still available.
