Bruce M
SHOBAM
Help / Advice
Symptoms , binding feeling in wheel while turning. Like a warn, loose ball joint or tie rod. All components check out OK. I think that I have a problem in the Rack & Pinion. Again never went too far into steering, done LCA’s, Tie rods, Brakes, and everything from motor swaps to 60K services to troubleshooting nearly all problems these beasts have. Not afraid to do anything, this looks scary in terms of time and equipment
Looked in the OEM Ford Factory Service Manual for 93 SHO regarding a rack swap out. They say I need to drop the cats & sub frame! ****, I can’t really see any other way! Might as well pull the motor!
Questions
1) Anyone done a Rack & Pinion Swap out.
2) Any tips
3) Do you have to drop the sub frame, is there a reasonable way around it.
Thanks
Questions
2) Any tips
Thanks
