Anybody have any ideas?
NetNinja
Hotlanta,GA, USA
The suspension replacement has begun and already it's kicking my ***.
Does anybody have any idea on how to remove the nut from the rear strut?
A crows foot does not work it's too freaking tight in there. Looks like some sort of special tool?
I can fit a deep well socket in there but I can't hold the strut rod to prevent it from spinning.
I wasn't able to get one of the banjo bolts off so Now I need a new rear hub assembly?
I guess I also need a new antilock brake sensor, I guess there is one bolt that holds it on but I can't seem to remove it. The Helms manual is no help.
:madflame:
projectSHO89
SHOless In St L
Are you throwing away or keeping the old strut?
If throwing it away, use a very large pair of Vice-Grips on the strut shaft since you don't have to worry about the damage it will cause.
What size socket fits the nut?
Steve
NetNinja
Hotlanta,GA, USA
Into the Trash
I am actually throwing it into the trash.
So I guess there is no point in trying to remove the mounting cup.
Since I am getting new cup.
You can fit a socket( Deep Well) in there but there is no way you can hold the strut shaft still. I think it's a 17mm.
You can use a regular 17mm socket but that's totally useless because you can't fit the ratchet on it.
pjtoledo
'ol man in the SHO
toledo,ohio,usa
There are 3 methods to get that nut off. First is the good'ol impact wrench. Several SHORT bursts should work, don't even have to hold the shaft. Method 2 is almost as simple. Get a hi offset box end wrench, either 21 or 22mm, can't remember which, maybe even a 13/16" will do. You may have to carve some of the lead away for a good fit. This allows a wrench on both the nut and the strut rod. Method 3 involves a 1/2" drive 13/16" sparkplug socket,,with a hex exterior at the socket end. Place a 10mm 3/8" drive socket on the rod end, place the spark plug socket over that, slide a 3/8" extension thru the 1/2" socket hole and into the 10mm socket. Hold the sparkplug socket with a wrench, and whatever works on the extension. Don't forget to pull the foam rubber out of the spark plug socket.
Perry
Jim Merriman
Southington, CT
One thing that wasn't mentioned here is that you have to be really careful with the springs! I usually use a wall mounted spring compressor to slightly compress the springs and take the tension off of the mounting caps (I call them top hats-BTW). Then I use a regular impact gun to take off the nut with a 6" to 1 foot socket extender.
The other way to do this is to use a portable spring tensioner. In that case, the devise uses a sissors like device and as you wind it in - it pulls the springs together from the ends, and takes the tension off of the mounting plate and the strut. To not use a spring compressor, is asking for big trouble in my humble opinion....... Be careful, they can rip your arm off!
DHMag
Free At Last
InCahoots, Texas
i have a wrench that will fit down in there. the advice about visegrips -> it works, but youll find they will slide along the smooth shaft. if you are replacing the strut, use a 32ox ball pein hammer and beat up (wail on it !) on the shaft to give the visegrips something to grip to.
NetNinja
Hotlanta,GA, USA
Thanks dudes.
Thanks for all the advise.
I now have another problem. Since the strut was such a PITA to get out I had to remove the whole assembly.
Does anybody have a part # for the bushings that go into the stamped steel control arms? I had to cut out the rear wheel spindle inorder to pull the struts.
This in turn destroyed the bushings because I had to drill out the rubber to get the remaning bolt out.
Yeah I used a hack saw to cut through the bolts on the right rear.
The left one allowed me to remove one bolt and the second one had to be persuaded.
I will have to bring the spindle to a machine shop and see if they can punch or drill out the remaining bolt. They were frozen solid to the spindles.
This is a Georgia car, I can imagine what a northern car would be like.
I will post pictures latter.
poffffd
