Any tips for front mail seal?
Lightning
Alberta
Being a ham-****** oilfield worker from way back, I just pulled mine with a banana knife.
(similar to this, but slightly shorter and heavier duty)
Only cost 2-3 bucks at the local industrial supply dealer.
Just slipped the tip in through the rubber of the seal and under the lip of the outer ****** and pried it right out. Took seconds and very little effort, just don't go too deep as it will easily nick aluminum...
RiceeatingSHO
Travis R
Alabama
It is in, I tried a WInchester knife and I broke the tip off lol, I got it and the tip out and replaced the seal, it tapped in pretty easy.
Lightning
Alberta
here is the actual knife I use. Use it all the time, especially at the wreckers, cuts almost anything.
Stanley makes one too,
5 bucks at Grainger. Cheap enough that even if you screw it up, you aren't out anything...
