Any recommendations for Methanol injection
802SHO
Boost > VE, MBT, Cams
Essex Junction Vermont
I was thinking alky but then I called LMS and they said it has to be direct imported . Do you have alky? If so did you direct import??also what tune do you have
LMS what a bunch of goofs! No you don’t have to have direct port meth...that’s them trying to upsell you more items...and even if you did want direct port meth...which overall is better yes...but not necessary....if you had them do it they would charge you +4,000 dollars for labor....and the funniest part of all is I bought my Alky kit(single nozzle) from LMS.....
I am for the most part AJP Turbo tuned.
yaycandy
Aerospace Engineer
Hanover, PA
Aem v3. Not aquamist but its a great deal with their most efficient nozzle tech and simple install and great support
Tom Moe
Metro Detroit
Do you think with 3 map, Tune, meth, cold air intake I can run around low 12's?
802SHO
I ran 12.0 with 3bar, Sp534 plugs .028, 160T stat, AirAid intake, upr catch can, catless downpipes with custom exhaust, Alky control single nozzle meth injection m15 nozzle 100% meth.
I also had trunk stuff out, low fuel, 20x9 Mickey Thompson sc-5 wheels, R1 brakes, continental extreme contact DW tires, 13+ Aux trans cooler, 93 octane meth tune from AJP Turbo.
Stock turbos, stock fuel pumps, stock intercooler.
September, think it was 60’s..low 70’s. DA probably about 1500ft.
BweegN
Springfield, VT
Reviving another one!
Any data out there on how long a tank of fluid lasts on avg (assuming tank size is 1gal)?
I'm sure there are many variables between tank, nozzle, throttle, etc.
This build will be my daily so, I'm really trying to decide if I want a dependent or cooling system.
But, if we're talking tuned +25hp on a hot day...$hit, that's a great mod to top off the benefit of cleaning at the same time!!
76FoMoCo
Nampa, ID
I go through about 5-10 gallons a year. M 5 nozzle 100% meth, cooling only and don't run it much in the winter.
bpd1151
Lurking Around
SHOcago 'Burbs
$30 !?!?!? Really? Holy heII.....
I guess that depends on market where purchased, and global supply issues.
Out here in the CHI.... a 5gal. container would fetch anywhere from between $60 - $85.
Cheapest I got it was for $38 a 5gal. container.
BweegN
Springfield, VT
Everything in VT is generally more expensive courtesy of our governing body. I'll skip that topic.
Finding 100% around here will be hard enough. By the time I do, I probably won't care what it costs. I do have a VP station just down the road that offers 91 no ethanol, I'll probably start there since I see the owner there quite a bit. *Fingers crossed*.
802SHO
Quintin Bros in South Burlington usually stocks it. But they want 79.99 last time I bought from them. Best thing I did was last time I used the car in 2020. I had enough left to get me going to start my new tune revisions then I filled up at New England Dragway at the Fuel Shack. $6 a gallon
76FoMoCo
Nampa, ID
I guess I should have mentioned. The place I get it is a distributor and I bring back my jug.
BweegN
Springfield, VT
Quick research on the V3 looks like a fairly failsafe system as long as you keep the nozzle clean.
The only other thing I could think of is to put an inline pressure switch/flow meter connected to an LED to monitor for pump failure which seems more common than it should be?
I'd love to be able to keep everything in the engine bay but I'm guessing that tank is just too big. As a daily I don't want to sacrifice my wiper washer either.
76FoMoCo
Nampa, ID
Alki moved the pressure switch post pump and filter on the newer version. Washer fluid tank is the best. Add the ax wiper tank
