DanStp
My 94 ATX is stalling. I have replaced since last summer the: timing belt, one tensioner, water pump, CPS, alternator, battery, and oil pressure sender, and last but not least the IAB.
It runs fine then will stall. On or off power, sometimes at idle. I ran codes and the code 551 Idle Air Control comes up. I had previously cleaned the old IAB, but that did not help. I then got a new one from Autozone, and still no progress. The 551 code still comes up.
There is one more thing while sitting still and running up the RPM's there is a bad hesitation around 4,000. I assume this something to do with the secondaries in the intake. I have 109,000 miles, and know I am close to another 60k well at least on top. I know I will pulling the intake and changing the wires and plugs to save $$$ myself.
Thanks for any help in advance
<small>[ January 22, 2003, 08:12 PM: Message edited by: DanStp ]</small>
