alternator light
thibertsho
montreal
what is a problem? alternator is new charge at 14.5 volt and the alternator light is on what the f......... is that*&?%$ :nut:
Loose or corroded plug at the alternator or a broken wire going to the plug.
element913
SHO Owner Elite
SF Bay Area, CA
Where are you taking your voltage measurement? There could be a problem with the voltage regulator also (as it is what gives power to the light). If your fusible link burnt out, the voltage at the alternator would still be high, but the battery would read 12v (or less). Take it back to where you purchased it and have them run a diagnostics (they can determine if it is infact a voltage regulator, usually with the unit still on the car). There are not many things that can go wrong to make that light go on (especially if your still seeing 14.5v). The battery light wire goes straight from the alternator to the bulb in the instrument cluster so I do not think its a corrosion issue.
-Mike
Mike Gallion
Marseilles, IL.
Let me know if you figure this one out. I'm currently in the same boat. Battery idiot light is on. New brushes, regulator and rotor within the last 6 months. Battery reads 12.7 volts after sitting all night. Alternator output is a CONSTANT 14.86 volts.
Either the plug on the back of the alternator is corroded or loose or the wires coming from it are cut or worn through somewhere.
