Alt & A/C Belt Help!
JRA2000TL
The Complainer
Daphne, AL
I feel really stupid....but I cannot get this new belt on my 95. I decided to change belts as preventative maintenance before the convention. I have loosened the tensioner pulley until it almost falls off (even tried installing it w/ the pulley off). I've loosened the 5mm hex nut/jack screw as far as it will go (it won't turn anymore). I've routed the belt around the crank pulley, under the tensioner pulley, and around the a/c compressor....now it's just a hair too short to go over the alternator. It's the Gates # K060445 belt, which is what I just put on the 89. What is the deal with this not wanting to go on?
FWIW, the old belt goes back on fine; I tried to reinstall it.
SHO1
Coke Is It!
The State Of Hockey
You just did this on the '89, right, so I assume you're doing it right? I don't know what the # is supposed to be, but does the belt # match the package #, maybe a mismatch? Or maybe the tensioner isn't getting as loose as it should?
JRA2000TL
The Complainer
Daphne, AL
Yep, checked the # on RockAuto, checked the # on the belt and the package. I did just do this on the 89 w/o issue. I changed the p/s belt and I just said eff it and put the old alt belt back on for now. I get a squealing, and after tightening the alt belt almost TOO tight, I still have a chirp....great. Now I get to pull out the battery and tray again and fight to get to that back tensioner and tighten it a little more if I can. Doing belts on these cars is a royal PITA. I hate it.
kevinspann
Don't take my advice.
Richmond VA
Weird. The other motor I have here has a K060441 on it, and that seems to fit. Did you compare the old belt to the new belt?
JRA2000TL
The Complainer
Daphne, AL
Yeah, they appear to be about the same, old belt may be a hair larger, but belts stretch, so :shrug:
No more squealing/chirping so whatever it was must have settled down....I'm taking my tools to the convention so if something gets out of adjustment on the way, I can correct it.
The p/s belt went on fine and has just enough play (less than 1" drop if you push down on it). The alt/ac belt had to be on TIGHT for it to quit chirping; which concerns me. Belts that are too tight can snap or screw up accessories. Oh well. Not sure if I want to fool with trying to put that new alt / ac belt on tomorrow. I was out there hours, which is shameful for something that should take 30 min or less. Funny b/c I ordered the same belts w/ the same part #s for the 89 and they went on fine. Maybe it's a defective belt?
Ishodu
I find it best to put it on the tensioner pulley last as it doesn't have a ****** on it.
JRA2000TL
The Complainer
Daphne, AL
Maybe that's why....I ordered this:
GATES Part # K060445 More Information About this Part Micro-V AT Premium OE V-Ribbed Belt; K06 13/16" x 45 1/8"
Ok....so I sat out there sweating buckets for 3-4 hours going "what am I doing wrong". LOL...wasted my whole Friday night too. What's worse is that I KNEW the part was right b/c it was the same # part on the 89....and I didn't know they were different for the 94/95s. That's why I was so persistent at trying to make it work. FAIL.:doh:
JRA2000TL
The Complainer
Daphne, AL
Oh yah...Archer is correct...diff size. RockAuto lists the 60455 as 46" compared to the 45-1/8" for the other. Ordering the right one now. $20 down the toilet for the other one unless I need it for the 89 later on.
Mr Anonymous
Tire Wall
Why order? Just go to the local parts store and buy one. With shipping you're not saving anything buying online.
Funny thing is, I just came upon a set of 94/95 MTX belts in the basement last night while putting together a box of stuff for the charity auction at the convention!
poffffd
