iselltonsofthings
I want to replace all four wheel bearings.
I called Advance Auto Parts and they are listing a wheel bearing or hub assembly with bearing for the front.
I understand that if a front wheel bearing seizes up to where it causes damage to the hub, that is why they sell the hub assy with bearing. I think I should be fine with just buying a bearing cause there is no grinding or wobble.
As for the rear bearing, they only sell the hub assembly with bearing.
Does anyone know why you need a whole assembly?
I do not have the rear knuckles removed from the car so I can't see. That is why I'm posting the question.
Is this an error in their computer system. Can I buy just the bearing, like I'm doing for the front, or do I need the whole assembly for the rear like what they are telling me.
Thanks. Scott
Thanks. Scott
