AVINO95
Well, since my dunlop SP 5000's are pretty much down to the wear bars on the front after about 3000 miles (gahhh!) I need to figure out what the **** caused it. The car is within the alignment specs up front, but when I took of the tires, and then shook the components under there the bottom parts seemed solid, but it seemed that the top of the strut was moving around a little on me, I would figure that was most likely the cause. The tie rod ends seem to be alright still. Any suggestions?
Also, the rear tires are also wearingkinda funny, the inside blocks of tread are kind of feathering on me. This happened in my 91 sable too and i was told there was no adjustment to fix that. Is this the case? I was thinking that perhaps my springs are sagging, and the constant compressed state of the rear suspension was the culprit, causing messed up geometry between the tire and the road. Any suggestions?
Thanks!!!!
Dave
Thanks!!!!
Dave
