AREA 91 said:
You have to remove the front portion of the driver's side wheel well. You will then be able to reach up in the inner fender, and pull the saxocone free from the outer air box.
I told someone this the other night... But its not hard...
1. Jack up the front after engaging the parking brake and chocking the rear tires. DO NOT attempt to jack the car if you do not have stands. Make sure the stands are in good condition and capable of holding the car. An alternative to jacking is to cut the wheels all the way to the right.
2. Remove the air box cover. I also disconnect the intake from the manifold. Stuff a rag or something into the manifold cover while doing this operation to prevent anything from getting into the engine.
3. Remove the air filter. Remove the three hex head bolts holding the airbox to the frame. (Two go straight down and one goes into the frame near the wheel well.)
4. Remove the two nuts holding the outside box to the frame. Remove the two screws under the wheel well holding the cover in the wheel well.
5. Pulling on the cover should give you access to the inside of the quarter panel. The outside airbox should come out with a little delicate manuevering.
6. With the outside box removed you can clearly see the cone inside the box. You can just push the cone out of the outside box. This will require some elbow grease! You now have a larger intake hole in the outside box.
7. Manuever the outside box back in to the wheel well. Replace the two nuts on to the bolts coming through the fender. Replace the inside air box and reinstall the three hex head bolts. Install the air filter.
8. Put the box cover back on the box. Remove the rag from the manifold and replace the tube over the opening. Tighten the hose clamp over the manifold tube. Clamp down the box cover.
9. Replace the two screws in the wheel well cover.
You can easily hear the secondary runners open during acceleration. Some think it is neat to hear the change in the engine sounds. It is not known how much if any this increases the power but it does sound cool. And is one of the easiest modifications to make.
What your removing looks like this...
The seconderies will sound a WHOLE lot better, plus it gives the engine more air to breathe at higher rpms.
-Mike
