ai bag code 51
92yamaha
ky
my air bag light came on and the code is 51 (Diagnostic Monitor Internal Thermal Fuse - Open Due to Intermittent Short to Ground ) and i don't really know what that is , so if anyone has any idea how to fix it please write.
projectSHO89
SHOless In St L
///From the Service CD////
Diagnostic Trouble Code 51
Diagnostic Monitor Internal Thermal Fuse Blown And Short To Ground No Longer Exists
Short to Ground was Serviced or is Intermittent
Normal Operation
NOTE:
The diagnostic monitor contains an internal thermal fuse that is not serviceable. The thermal fuse is controlled by the diagnostic monitor. The diagnostic monitor will blow the thermal fuse whenever a short on the deployment circuits occurs. The thermal fuse does not blow because of excessive current flowing through it. DO NOT attempt to jumper out the thermal fuse with a circuit breaker or any other type of fuse.
WARNING:
DO NOT INSTALL A NEW DIAGNOSTIC MONITOR UNTIL THE SHORT HAS BEEN LOCATED AND CORRECTED. IF A SHORT TO GROUND HAS NOT BEEN LOCATED AND CORRECTED, THEN THE SHORT TO GROUND IS INTERMITTENT AND IS NOT PRESENT AT THIS TIME. INSTALLING A NEW DIAGNOSTIC MONITOR WITH AN INTERMITTENT SHORT IN THE SYSTEM WILL RESULT IN REPEAT BLOWN DIAGNOSTIC MONITORS AND REPEAT SERVICE.
The diagnostic monitor measures the voltages at the diagnostic monitor connector Pins. When certain air bag deployment wires are shorted to ground (heavy lines illustrated in the schematic below), the system may become susceptible to unwanted deployment of the air bag(s). The diagnostic monitor senses a short to ground on any of these circuits and helps prevent unwanted air bag deployment by blowing the diagnostic monitor thermal fuse. Blowing this fuse removes all power (battery and back-up power) from the air bag deployment circuits. While the short to ground exists, the monitor will flash diagnostic trouble code 13 or code 14, depending on where the short appears (see code 13 and 14 for more details). If the short to ground is intermittent and temporarily corrects itself, the diagnostic monitor will flash code 51.
NOTE:
If the short to ground returns, the higher priority codes 13 or 14 will be flashed instead of 51.
If the Air Bag indicator is flashing code 51 and a short to ground has not been serviced, this means that an intermittent short to ground exists in the air bag system. The diagnostic monitor should be replaced only after service of the intermittent short has been completed.
Some service tips for finding an intermittent short to ground are:
1. Consult OASIS (Restraint Systems Service Code 104000) for up to date diagnostics and descriptions of wiring concern locations for the vehicle (VIN number) you are working on. OASIS is updated daily using concern descriptions from engineering and Dealership Service sources.
2. Inspect wiring and harnesses in areas where they pass through or are located next to metal components (i.e. engine compartment bulkhead, body sheet metal, component mounting brackets, etc.)
Code 51 After Air Bag Deployment
NOTE:
Diagnostic monitors can withstand several air bag deployments and do not need to be replaced after every deployment. Only replace the diagnostic monitor if it is damaged.
Occasionally, after an air bag deploys, the internal wiring of the air bag(s) may become shorted to the metal housings of the air bag(s). This internal air bag short is detected by the diagnostic monitor as a short to ground in the air bag deployment wiring. Since the diagnostic monitor is still operating immediately after most deployments, the monitor will detect the short and will flash code 13 and blow its internal thermal fuse. After the deployment, as the air bag(s) cool off, the internal shorted wiring may correct itself, therefore the short to ground will no longer exist and the diagnostic monitor will flash code 51. If a vehicle with a deployed air bag is flashing code 51, inspect the vehicle for crushed wiring, sensors, etc. and replace as required. If no damage is found, assume that the deployed air bag was the cause for the intermittent short and replace the diagnostic monitor when the new air bag(s) are installed.
After a short to ground has been corrected, the diagnostic monitor will flash out Diagnostic Trouble Code 51. Diagnostic Trouble Code 51 indicates that the thermal fuse inside the diagnostic monitor is blown and the short to ground no longer exists.
If a short to ground has not been located and serviced (short to ground corrected itself), consult OASIS for potential wiring shorts.
If a short to ground has been correctly located and serviced then replace diagnostic monitor. DO NOT replace diagnostic monitor until the short to ground has been positively located and serviced. Replacing diagnostic monitor before servicing a short to ground will result in repeat service.
/////End quote/////
There are more diagrams, but they don't cut n paste...
Steve
92yamaha
ky
the light is still on and i am not sure where the grounds are located and which ones to check , please reply if you know how to fix it.
projectSHO89
SHOless In St L
I'd recommend that you leave this to a professional.
Steve
rangerj
Brunswick, Ohio
92,
Please listen to Steve on this one. LET A PROFESSIONAL FIX THIS PROBLEM.
If you start probing around a live air bag system, that has a short somewhere, you could set off the air bag. rangerj
