87hurricane
Ok, I did a few searchs, and I think I found most of the info I need, but I still have a couple of quick ?s for those who know. I have a 92 SHO with Premium sound system, all stock, and I am going to put in a new head unit. It looks like I have a couple of different options for wiring the speakers, use line convertors and the stock amps, get a wiring harness that connects to the stock amp harness and a jumper for the stock amp, or use the other harness under the dash that runs directly to the speakers. I believe I'm going to ditch the stock amp, and I think I'd rather use the "extra" speaker harness that bypasses the amp since it has larger gauge wire that the tiny wires runnning back to the amp. I'm assuming that the extra harness is there for cars that weren't equiped with the premium sound, so can I just get a adpater for a SLO or SHO without premium sound? Finally, I'd like to discconect the amp/amps after I bypass them, I have two little boxes on the rear deck, a silver amp on the right, and a little black box on the left. From what I've read, the black box is a sub amp? I don't have a sub, but if it is an amp I'd like to disconnect it as well. Is the little black box a sub amp, and if so, will I have any problems if I unplug it once I bypass the amps? Thanks in advance guys.
Dave
Dave
There are two connectors in the trunk also. I'm in the process of soldering RCA's to the SCOSCHE FDK106 that was suppose to be the correct harness for the car... NOT.
