AFter plug/wire change...
sephiroth90White
Utah
I just changed the wires/plugs on my 90 sho, i had to remove the headers to get to the back plugs, anyways now i'm getting blue smoke out of my tail pipe. is this normal? i mean should it clear up after a bit or did something happen?
SHOnuff93
Dublin, Ca
why the **** did you remove the exhaust manifold? this was not necessary, you may remove the intake to ease sparkplug changing, but not an exhaust manifold. and no it should not smoke, but it might just be oil that drained inot the cylinder while the plug was out.
sephiroth90White
Utah
i didn't remove the exhaust manifold only the intake, and thats was my original therory is that somehow a little oil from the spark plug wells did get into the pistons
BeatDaSHO
Hatboro, Pennsylvania
geez. bad idea man. that oil probably had some dirt in it which is now all in ur cylinder. BAD idea. you should have sucked it out with something before you pulled the old plug out.
Greg
sephiroth90White
Utah
ugggg, that sux.... well i don't think hasly anything got in ther just enought to make it smoke. i hope it clears up... dammit....
You might have just disturbed the oil that was sitting in your surge tank and runners. First time I did my V8 I thought something was wrong as it blew out smoke for 15 miles.
sephiroth90White
Utah
yeah i thought something along the same lines, i'm gonna drive it tom and i hope that it will just clear out...
