Electricat
I recently purchased a Royal Blue '95 ATX SHO, 113K miles. It was non-running when I got it, replaced the CID and it ran great. The only code it was showing was a 326. The previous owner did a lot of work to the car, but the plug wires appear to be original, so replacement is obviously in order. No oil seen in the plugs wells.
The cats had been cut out by another previous owner, so I replaced the Y-pipe with a used one. It ran decent at first, but quickly (within 10mi.)got worse, now it idles and runs rough at all RPM's, and at one point had the cats glowing red. Checked codes, and here is what I got:
172 - Oxygen sensor not switching - system is or was lean - Single Right or Rear HO2S
173 - Oxygen sensor not switching - system is or was rich - Single Right or Rear HO2S
176 - Oxygen sensor not switching - system is or was lean Left or Front HO2S
326 - Pressure Feedback EGR shows low pressure EGR not seating or not seating intermittantly
332 - EGR did not open/respond during test or if memory code did not open intermittantly
335 - EGR feedback signal is/was out of range
542 - Fuel pump open bad ground or always on
I'm thinking to replace the plugs and wires, both O2 sensors, and the EGR valve.
I'm also concerned about the cats, and whether they were/now are damaged. No noticable rattles, but they got awful hot. Could they be a part of my problems? Any other suggestions on this?
I appreciate any help on this! I have a good automotive background, although the SHO is the most complex vehicle I have ever owned. I'm looking forward to learning and driving this thing!! It is discouraging to have problems with it right away like this though! THANKS in advance!
