I am planning ahead to replace my front struts (110,000 miles currently).
From past experience on other vehicles I know that usually spring compressors do not create enough ro0m to get the strut free. Plus, I am going to use Monroe quick struts.
Anyone know the most essential components that require removal to make this as efficient as possible?
I am thinking:
1. Remove axle nut (to avoid pulling the half-shaft free of transaxle).
2. Disconnect stabilizer link (to allow additional control arm/spindle movement movement).
3. If necessary, remove the tie rod end from the spindle (to allow increased spindle movement).
4. Use floor jack below spindle/brake assembly to avoid undue pressure on the brake hoses, ABS wires.
5. Note strut mount orientation on remove/install to maintain correct factory camber.
My questions, to anyone who may have performed the procedure are: Do I actually need to remove the tie rod end? And is there anything else I am missing?
Of course , if someone were to upload the FOMOCO WS manual PDFs with torque specs and procedure, I would be grateful.
TIA guys.
I am thinking:
TIA guys.
