Adding New Speakers
pfcjohnson
Duluth MN
THis is my first time posting. I have a black on black 93 SHO. Im trying to add speakers to go with my new cd deck, but i cant get the door panels off to replace the front speakers. headbang Please help me. It would be greatly appreciated.
pfcjohnson
Duluth MN
Thanks for the info. I had searched for a long time and found nothing. It too late for me to do it tonight. I'll tell ya how it went tomorrow. Once again thinks.
James Downing
Virginia Tech, VA
removing the door assembly is pretty easy, just dont be afraid to use some force. there are two screws you will need to remove, one i think in the door pull lever...
Then stick a screwdriver in the bottom of the door, and begin prying. Just dont forget the plugs. I did it without instructions. Its fairly straight foreward.
30footSHO
In da mountains
Boise, ID
But if you're using a screwdriver, make absolutely sure that you have removed all the screws, as well as the sail panel in the front corner of the window.
pfcjohnson
Duluth MN
I got my front speakers in, and they look great. You can see the white sho through the cover on the door. I like this look cause it matches the white paint i used to fill in the SHO lettering on the doors and bumper. I still have to put the 6/9's in the rear deck, but i dont think that it should be a problem. Thanks everyone! For your help and info.
