Acceleration shudder over 65mph
hawkfandan
Iowa
Have 11 SHO. Have replaced plugs, wires, boots, most coils and all the fuel injectors.
I recently had a cylinder 3 misfire and changed the coil and plug (the plusg a 2nd time) and yesterday my cel went off is when doing.a hard acceleration over 65 (up a hill.or passing).
Mainly had done all city driving since the aforementioned plug replacement.
Car shirts good, drives good otherwise no issues with acceleration.
I've spent thousands trying to get it right. I need some ideas what could be wrong!?!
swap the #3 coil with another and see if it follows. It's always possible to get a replacement that isn't as good as you would think. After that if it keeps being same cylinder specific then there is either a fuel, vacuum issue, or something with the circuit firing the coil or a cylinder internal specific issue. The easy stuff has been done it looks like.
To get better responses you need to post this in the Gen 4 section that is specific to the newer turbo models of SHO. This section is the early non turbo cars
bmytych
