I have a 95 SHO ATX, I have replaced several sensors, TPS, IAC, EGR control,02 sensor bank 1, knock sensor. Up until replacing the knock sensor it was the only one kicking out a code, after replacing it it started kicking out the bank 1, 02 sensor again. The engine runs good under moderate exceleration, but as soon as you push it to the floor it fall on it's face..
I'm sure I'm not the first one to encounter this problem. Can anyone give some insight as to what to do? Any help is truly appreciated.
ShoJockey
ShoJockey
I was told by the fella at the parts store that the #1 bank was at the front side of the car.... talking with one of the mechanics at work, he said "Don the right side is the side closest to the fire wall, or right side if you were sitting behind the engine", Who knew....
