ABS indicator rings
pritch55
Minneapolis, MN
Does anyone know if you can use an ABS indicator ring off of any taurus. I have a 91 MTX and I'm thinking of going out to the junkyard this weekend to pull one, but I want to make sure that it will work off of a SLO. I remember reading that the 3.2 ring and 3.0 ring for the SHO's are different sizes but any help would be greatly appreciated.
RStalveyARFF
too many shos
Georgetown, MA
I don't believe the rings cost that much money from Ford. There is a how to in the "how-to" section on how to replace these rings.
gregr
Orange County, NY - USA
Here is the link to the How To article I wrote:
http://www.shoforum.com/ABSrings.htm
Don't get them used. I don't think a standard taurus one will fit anyway. Also, the 3.2 and the 3.0's are different as well. They are about $30 or so, I forget, but you would probably break it removing it anyway. Give your self a couple of hour do do this project. it can be a headache if the shafts have rust on them. Good luck.
Greg Raciti
SHO Forum Webmaster
93 Emerald Green MTX
Performance Plus high flow stainless Y-pipe
Scott 2.5" Mandrel Bent Stainless
Exhaust with Edelbrock mufflers
SHOShop Cold Air Induction
SHOShop Underdrive Pullies (to be installed)
Romar Enterprises Subframe Connectors
SHO NUT Performance Aluminum Subframe Bushings
24mm front sway bar
26mm rear sway bar
Energy Suspension poly bushings
