Abs brake failure caused my wreck need help!
sperold
Last to Know
Check to see if your rear brakes are grabbing and releasing when you stab your brake pedal. You will need 2 people for that one.
The SHOs have problems with the rear flex hoses collapsing internally (usually due to the metal attachment holder rusting and closing off the hole), and I imagine yours are doing the same thing.
That is more important than checking your ABS components at this point.
North Carolina
I will definably check that out!
Off Road SHO
Moderator
All this aside, am I the only one finding humor in the username? :p
All this aside, is Bob the only guy that doesn't read the whole thread before he posts in it? Just messin with ya Bob.
To the original poster; if you need a set of front brake lines, ABS pump, ABS computer, see my for sale ad in SHO Parts Forum.
Good luck, brakes on these cars are maddening because of rust, neglect and or improper maintenance.
Tom
Westerly, RI
Tom
I've always preferred to blindly jump my way in Tom. :)
