a stuck arm
ncfirefighter
north carolina
a stuck A arm
i have to replace my left axle and the Arm is stuck and i have done busted a darn puller on it and now i have the weight of the car on that one ball joint and it still wont give what is there left to do this thing is nutz
Allmostall
North Carolina
I had to remove the whole knuckle with lower arm attached and use a press
to get the ball joint out of the lower arm.
ncfirefighter
north carolina
well thanks for the info but i used a grinder today and cut the ball joint into. would have used my torch but i was out of gas and can get it filled on sunday :doh: but i know am using antiseze when i install a new one. that what to book says is :hpoop: tells you to use a pry bar to break the ball joint lose from the knuckle. :lol:
