Inkertinker
Well-Known Member
The A/C took a crap a couple of days ago. Finally decided to remove the shim for the compressor clutch. Did some reading here and did a lot of looking in the engine bay. I was not real excited about lowering the sub-frame, but I could not get a wrench on the clutch nut no matter how I tried. I read that the nut was a 14 or 15 mm so I took some spare 6 point sockets that I had into work. Had Ted (a machinist at work) cut the socket down a weld them on some 1/4 inch flat stock about 16 inches long. The new "tool" was still too wide for the space between the frame and the compressor. I was able to grind the socket down until I had plenty of clearance. With a long screwdriver to I was able to hold the clutch while I broke the nut loose. It worked very well. I did not remove the belt, I did the wrenching from up top and pulled the nut, clutch and shim from under the car. It took several tries to re-install the clutch because I did not notice the change in the spline teeth at first. Once I found that I was able I line-up the notch and the clutch fell right into place. By the way it is a 14mm, the 15mm that is welded in the other works great for serpentine belt removal.
